DSC - HX400V Camera Memory
Dunworkin
Hi All - I have a 32G SD card in my HX400V but receive 'Card Full' message at only 4G.
Is there anywhere within the camera that I can check that the 32G is recognised/available ( less any used memory) or some indication of remaining/empty SD card space?
The 32G registers OK on a card reader.
Any advice appreciated.
Many Thanks
Dunworkin
Dunworkin
Hi Betreff - Firstly...Sincere apologies for not replying sooner to your response, for which I thank you.
Card is a SanDisk and genuine (as far as I know!).
Problem seems to have righted itself.  I managed to track down camera card volume.....stupid me expeceted it to be listed under 'Memory' when it is actually detailed under the heading 'Media'.
Thanks again for your response.
IamNic
Hello @Dunworkin,
which card are you trying to use and where did you purchase it?
To me it sounds like a counterfeit card, which has less memory than it suggests to have.
- Nic
Dunworkin
