DSC-HX400V
bexbarcar
DSC-HX400V
I recently bought a DSC-HX400V and set up to have GPS information attached to my pictures.
I find that sometimes the data appears and sometimes it does not.  This appears to be somewhat random.  I can take one picture and it has the GPS data and then the next picture won't have the GPS data.  Is there a reason or is there a fix to ensure that it does appear every time?
sgheki
Probably there is not enogh time to set the staellits. If you use your phone to navigate, then you see that need time to get the sign. I think here is the same situation.
bexbarcar
Thanks for your comment.  However, I never actually moved from where I took the previous picture.  Strange!!
