I have downloaded the handbook but when I want to view it a box appears saying it wants a PDF security password, it then says Please enter the document permission password to remove the restrictions, can you please help me.
Message was edited by: Yorky4
Solved! Go to Solution.
Hi Yorky4
It may be a setting on your PC; I've just downloaded and opened it without a problem. Here's the link I used, hopefully it will work for you too:
http://pdf.crse.com/manuals/4172668121.pdf
Mick
Hi Yorky4
Mick
Hi Mick
Thanks very much for your reply
It worked perfectly
Yorky 4
