dsc hx90V
Gramski
dsc hx90V
great little camera - but now every time switch it on the lens protrudes then retracts again flagging up "switch power off and then on again"  I tried taking the battery out - keeping the power button pressed for 30 secs etc with no change.  I've also tried resetting it but by the time I try to initialize reset the switch it off then  on again flag pops up and blocks it.    Can anyone suggest a fix?  Or does anyone know if its a relatively easy and inexpensive repair at a sony dealer?
0 REPLIES 0
