DSC-TX5: camera turns itself off after 5 seconds
brendanmcerlain
Hi everyone - i've had my camera for about 18months and never had any problems. Now when I try to use it, the camera comes on but turns itself off after about 5 seconds. I've recharged the battery - same problem. I reset the camera - same problem. I bought a new battery and fully charged it - same problem. Whether I leave the camera alone or try to take a photo / record a movie, it just turns itself off. The battery indicator in the top right hand corner has also disappeared. Anyone got any ideas on what is wrong or had a similar problem??
Thanks - Bren.
blaireau_photo
Hello Bren - welcome to the Sony Forums :slight_smile:
If you have taken all of these steps and have seen no improvement it is probably an internal fault within the camera and you may wish to find out how much a repair will cost to see whether it will be economical. To do this, I would advise you to contact Customer Services who will be able to advise accordingly. All if the details are in this forum thread:
http://www.sony.co.uk/discussions/message/651957#651957
Thanks,
Simon
blaireau_photo
Thanks,
Simon
brendanmcerlain
Cool .. Thanks Simon.
Bren.
