DSC-W100 Error
profile.country.de_DE.title
TimoChr
DSC-W100 Error
since a few days my camera only shows error message when switching on. Directly after switching on the display shows "accessing" and the objective is moving out and in a few times.
Finally the objective moves out completely and the display shows "switch off and on again" only.
I cannot use the camery anymore.
Anybody any ideas how to solve this issue?
Thanks in advance,
Timo
Tags (3)
specialist-convergence
Hi it would appear you camera has a fault with the lens.  please visit link below for repair information;
http://www.sonydigital-link.com/dime/digistill/cyber/cyber.aspx?site=odw_en_GB&m=DSC-W100
profile.country.mk_MK.title
WNildd
TIMO I really need ur help
What happend with ur camery .. that U saiid .. ??
My photo digital is DSC-W35
and when I turn On it says TURN THE POWER OFF AND ON AGAIN ..
WHAT CAN I DO WITH THAT ?
07.6.2011 IS MY PROM NIGHT IT MUST WORK THAT NIGHT I REALLY NEED UR HELP .. :smileyplain::smileysad:
profile.country.sv_SE.title
jes7jes
The same thing happened to my DSC-W380... And a friend said the same happened to her SONY as well.
To bad it happened on my birthday exactly one year after it was bought, so we couldn´t make it in time to use the warranty.
/Jes
