The message you are trying to access is permanently deleted.
I can find firmware for the 100M5 but not the 100M5A.
I guess it is too different to use these updaters: Update_DSCRX100M5V101 and Update_DSCRX100M5V200.
Not a huge problem, but one of the Sony Apps said it would not work for my camera unless i updated the firmware, so I started looking.
Anyone found the firmware anywhere?
Its a new camera (for me) but obviously a very old model. Does what I want though....
ATB
A.
Solved! Go to Solution.
There is no new Firmware for the M5A:
https://www.sony.co.uk/electronics/support/compact-cameras-dsc-rx-series/dsc-rx100m5a/downloads
