Film format of HDR-PJ10E - AVCHD
profile.country.cs_CZ.title
stoupa.xxl
do you know what is exact film format of HD video from HDR-PJ10E. In manual I found that it is compatible with H.264 and AVCHD.
I have Sony Vegas Movie Studio HD Platinum 10.0 and I would like to set output video format in the same configuration as origin to prevent rendering of original video. Rendering of parts with transitions is of course without problems.
Please help me!
Jan
Mick2011
Hi Jan, welcome to the Sony Forums :slight_smile:
Your camera records HD video in MPEG-4 AVC, which means the file output is H.264. You should be able to use H.264 from source (camera) to BluRay if you want, as all BR players are able to read that format by default.
If you have any problems with it, please don't hesitate to ask.
Mick
Mick2011
Mick
