How do I clean the lens on my Sony DSC-WX1?
profile.country.sv_SE.title
bjbergq79
The stain seems to be somewhere on the inside when I zoom in. they look like small worms.
blaireau_photo
Hello bjbergq79 - welcome to the Sony Forums
If the stain/blemish appears to be internal, it may indicate damage to the inside of the camera. If it is just a stain, dismantling your camera to try and clean it could invalidate the warranty or could lead to damaging the camera further.
Because of this, I would contact customer services using the details given in this forum thread:
http://www.sony.co.uk/discussions/message/651957#651957
They will be able to let you know if the camera is under warranty and if not, you can find out about repair/internal cleaning costs.
Thanks,
Simon
blaireau_photo
Thanks,
Simon
