HX80 camera help!
xkatana
HX80 camera help!
 I have the DSC – HX80 and I am having trouble turning the camera on. Battery is fully charged and the lens is stuck out. But when I press the on/off button it is not turning on.  is there anyway to fix this?
Tags (3)
I had similiar problem try taking out battery and re install battery.
Also on off button maybe sticking. Make sure you press it down sounds silly but it is a very small button.
