I have problems with DSC-WX350 transferring images
profile.country.AR.title
Mariobrizu
Dear community,
I have problems with my camera when I try to transfers images via WiFi from my camera to a tablet or smartphone android 10.0.
It's possible just with an old smartphone SAMSUNG J2 android 6.0.
Sony answered my that I have to upgrade the firmware 2.0 (2014). But I can not find upgrading software for this problem. Even remote control of the camera.
Joe_Dohn
Specialist
I believe the update is for the camera. Here are the links for Windows and Mac.
Mariobrizu
Unlikely there's no more upgrade of firmware for this model of camera.
Thanks in anyway.
Mario Brizuela
profile.country.NL.title
Strampke
There is hope my friend.
Just go: https://www.playmemoriescameraapps.com/portal/
Sign in, find SELECT and tap <all applications>
There you will find your camera.
After that explore.
Once you have connected your camera it will update as well as you can find some apps to engage your camera experience.
If you can't find your way, come back and ask.
