I-manual and the middle ages!
profile.country.sv_SE.title
fallah
RX100 Mnual: Why cant I download the whole of the Cyber shot user Manual, the so called I-maual?! Sony does not give us the full manual with the product! At least they could make it easier to download the whole of the manual to have hany when needed - or even print it fully for reference!
profile.country.de_DE.title
cmosse
Hi there,
I have created the PDF version of the DSC-RX100 cyber-shot guide (i-manual).
It can be downloaded from here:
https://www.dropbox.com/s/6i69wm6t3e10ycf/DSC-RX100_Cyber-shot%20User%20Guide_EN.pdf
The PDF was created with Adobe Acrobat and all links are active so you can navigate in it the same way as online.
Best Regards
Michael
5 REPLIES 5
Hi fallah and welcome.
You may find this recent discussion of interest: -
https://www.sony.co.uk/discussions/message/796196#796196
It seems there are some full versions on Dropbox but I don't know how to Search/Access them.
:thinking:
cmosse
Hi there,
Best Regards
Michael
penwith
Hi Michael.
RX100 is a nice little camera - but I too could not download the user guide.  Sony offer various manuals to download - the pdf ones which I could download were just the same as the printed guide you get with the camera. What I guessed was the fuller versions I could not  download.  I found my user guide by googling and downloaded it from; http://http://www.physics.byu.edu/faculty/colton/Sony%20RX100%20User%20Guide.pdf
This is the first Sony camera I have purchased and am amazed how poor a service they offer.  How strange to make it very difficult to get a copy of the full user guide. Sony should not have to rely on good guys like yourself.
Malcolm
blaireau_photo
Hello Malcolm - Welcome to the Sony Forums :slight_smile:
Have you tried downloading the version that cmosse mentions in the post above? The one that you posted is coming up as a dead link for me.
Thanks,
Simon
penwith
That's great, thanks Simon.
The cmosse link you mentioned produces a far better pdf file than my link. In my version the links are not active if you are not online.
Malcolm
