When I turn off power the lens retracts and then bounces out and stays out. Also, nothing can be seen through the screen so I can't use it at all. It is just over 2 years old and I am using the original battery and memory card
Solved! Go to Solution.
Thanks Jumpsuit. I fully charged the battery this morning and the camera is working now. If it happens again I suspect I might have to replace the battery
Hi @denismoore2000 and welcome to the Community
Have you tried removing the battery for a while,
(an hour for example) and then trying to power on again?
Hi again
Glad its sorted
