Magenta shift at ISO100 shutter 1/8
profile.country.FR.title
360HDRi
Is anyone else experiencing this?
I take bracketed exposure 360 degree images.  I've noticed that at shutter 1/8 ISO100, I get a nasty magenta wash over the image.
Looking back, all my pics since I purchased my ILCE-6300 have that problem. I want to check with the community to see if I'm the only one.
Best is to set your ISO to 100.
Set your shutter to continuous, 1/8 with brackets 3 shots 1 EV apart. (This will generate 3 captures: 1/4, 1/8, and 1/15).
Get a fairly dark exposure (under expose) since that's where it's most visible.
Open ARW in adobe camera raw and boost exposure  +5.
As you can see in the image below, the picture with shutter 1/8 is not good. Am I alone?
IamNic
Hello @360HDRi,
is it just the preview image or does it still look magenta after you open it up in another software?
- Nic
360HDRi
Hi @IamNic,
All softwares. Photoshop, Bridge, PT-GUI, IMF_Disp, XnView, RV, etc... It's more or less apparent depending on how each software handles thumbnails. My process usually involves 16bit conversion in dcraw, followed by a 32bit conversion in either photoshop or Nuke. The problem is already noticeable on the raw file with the simple expo boost in ACR. I've used a different lens and was easily able to reproduce.
