PAL/NTSC
RocketRon900ss
PAL/NTSC
I have the RX10M3 and have it set to PAL for the UK format. However I wish to be able to take still shots at the same time I am shooting video. This does not seem to be possible useing the Pal format.If I swith to the NTSC format to alow this, will it have any bearing on my still or video footage. all video footage will be edited in EDIUS 8 prior to viewing.
Ron
[Edited to remove personal information]
IamNic
Hello @RocketRon900ss,
unless whatever you are shooting is lit by AC powered lightsources, you won't have any problem.
- Nic
