PlayMemories Website - Timelapse Purchase Problems
profile.country.AT.title
Suiris
Dear all!
I have been trying to purchase the timelapse application on my RX100 IV camera, but I am unable to finish the process. After finally confirming that I want to purchase the application an error occurs.
Installing the free App „My best portrait“ worked fine though.
Could someone please fix this?
Thanks & Kind regards
Suiris
Dear Black Rose,
this hint should have come from Sony support, thank you very much! First I tried it from my iMac, this approach failed for unknown reasons (could never establish a connection to the camera, used Safari and Google Chrome). Then I used a Windows device with the Google Chrome browser, this worked perfectly.
Getting this app on my camera was ridiculously complicated and time-consuming!
Suiris
6 REPLIES 6
Pascale_F
Moderator
Hi Suiris,
Welcome to the community.
I'm just going to try to find some answers for you. In the meantime, maybe someone else in the community might have some ideas.
Thanks,
Pascale
Suiris
Hi Pascale
Thank you, PlayStation Support has also been involved (incident 190122-002256).
Kind regards
The_Black_Rose
Specialist
Hi Suiris,
Have you tried installing the application from the PlayMemories Camera apps website itself then moving it to the camera?
You can access the website using this link: https://bit.ly/2RShHFK
Cheers,
The_Black_Rose
Suiris
Dear Black Rose,
Suiris
The_Black_Rose
Specialist
Hi Suiris ,
I'm glad it's resolved and you can finally enjoy using your camera.
Cheers,
The_Black_Rose
MikeR_UK
Hi Pascale_F,
I'm just wondering if you had any luck finding an answer to this that doesn't involve using a Windows machine (I don't have one). So far as I can tell, the purchase app function on the camera is broken - I get the same error screen as Suiris and attempting to install it via a Mac doesn't work on either High Sierra or Mojave - in both cases, the Sony PlayMemories Camera Apps downloader does not install correctly which means you can't download the applications.
This is really frustrating and I can't see anything on the PlayMemories support pages to help.
Thanks in advance,
Mike.
