RX100 camera lens stuck
frasrob
Any suggestions please?  This seems to be s common / design problem.  If I take the back off the camera the lens works properly, but as soon as it's reassembled the lens sticks.  Any advice, especially from Sony, would be much appreciated.
EdwinaU
Moderator
Hi there,
Welcome to the community, thanks for reaching out to us.
If you'd like advice from Sony it's probably best to contact support about this here.
Best wishes,
EdwinaU
frasrob
Thank you, I have contacted Sony but with no useful response.  So far I'm told (by a quality camera shop) that it will cost £150 to repair the camera, which is not ecomonically viable.  So I am left with a high performance Sony camera that is totally useless.  Very disappointing.  Why does it work with the back removed, but not with it assembled?  Crazy.  Has anybody found a cure for this lens sticking problem please?
