Sony Cyber shot RX 10 ll
frmulve99
Hi, l am looking for advice on which 360 Degree Electric panoramic head would be best to purchase as camera weight seems to be an issue, the ones l have reviewed give you a weight that they support but then you look at reviews and some are contradictory wondered if anyone as one that works ok and tilts and does timelapse etc,
Thank you.
IamNic
Hello @frmulve99,
the Syrp Genie Mini could be the right 360° device for you.
- Nic
frmulve99
Thank you so much I will check it out and get back to you👍👍
