switch off problem
zara009
switch off problem
My sony DSC-W350 auto switch on after switch off.
Mick2011
Hi zara, welcome to the Sony Forums :slight_smile:
Have you tried to reset the camera?
Remove the battery, press and hold the on/off button for 30 seconds, replace the bettery and switch on again.
Let me know if that helps.
Mick
Mick2011
Mick
Does this work with the RX100? I switch it on and it works - however the next time it may or may not. To get round it I romove the battery, push it back in again (straight away) and it's off working, It's just a pain not knowing whether it'll start or not
Just tried it ....and it seems to
