Timelapse in RX100
profile.country.ru_RU.title
redfox_r
Timelapse in RX100
Hello!
Will Sony implement timelapse in RX100 in any new firmware?
Sad to don't have it in a such advanced hi-end camera :slight_frown:
7 REPLIES 7
blaireau_photo
Hello redfox_r - Welcome to the Sony Forums :slight_smile:
I don't know if this is something that is in the pipeline but any releases for this camera model will be published on the official support page which can be found here:
http://www.sony.co.uk/support/en/product/DSC-RX100/updates
Thanks,
Simon
redfox_r
Thank you, Simon!
Is there any thread which Sony developers read to place this proposal? Maybe some wishlist for new firmware updates or improvements?
Alex
blaireau_photo
Hello again :slight_smile:
As far as I am aware, developers at Sony often read all areas of the forums so your comments here should be noted at some point.
Thanks,
Simon
profile.country.de_DE.title
cmosse
Search for "TempusALL"
it is a mechanical intervalometer which should support RX100. As the RX100 does not support any classical remote control (IR or cable) this is the only solution
redfox_r
Yep, I thought something like this too.
But extra $150+shipping? While competitors like "Nikon 1" already have it :slight_frown:
It's not so difficult to add another drive mode, isn't it? But it would be much more fun with the camera, and another colorful feature to advertise :wink:
(of course, if you have some Light... in the ...room :smileylol:)
profile.country.fr_FR.title
bertram39
I thought too, to buy a Tempus All Mechanical but it's too expensive. i'm sure that it's not so difficult to install this function in a new firmware !
So I pray Sony Developpers to add timelapse for Rx100....Pleeeeaaase !
blaireau_photo
Hello bertram39 - Welcome to the Sony Forums :slight_smile:
All I can really say (aside from the alternative suggestion from cmosse which would be the best solution in the circumstances) is that Sony developers to read these forums on a regular basis and so any feedback that you leave here will be taken into consideration in the future.
Thanks,
Simon
