I have a sony cyber shot underwater camera, can I use the record setting under water with this camera?
Hello llorrac99 - Welcome to the Sony Forums
Could you please confirm exactly which model of Cybershot camera that you have and I can check this out for you (there should be a product code on a small sticker - usually on the base of the device).
Thanks,
Simon
If it is an underwater camera, you would be able to use all of its feature.
