Our new IFA products – The QX1 interchangeable smart lens camera
jaylward
2,855  Views
Author: Sony Europe
The QX series has always been about being adventurous with photography, and the QX1 smart lens camera is probably our most creative QX camera yet.
Thanks to an interchangeable lens function, you can experiment by using different lenses in different scenarios all while maintaining the sense of portability and playfulness that you get with all our QX cameras.
The other big feature is the built-in flash that makes the QX1 perfect for low-light situations. And once you’ve got that perfect creative shot, you can edit it quickly and easily using the new PlayMemories 5.0 app.
Key specifications:
  • Interchangeable lens function that supports all E mount lenses (and all A mount lenses when used with an adaptor) makes it possible to experiment with all sorts of different shots
  • 20.1 megapixel APS-C sensor, BIONZ X imaging processor and high ISO range of 100-16000
  • Built-in flash makes it perfect for shooting creative photos in low-light situations
  • Editing photos is quick and easy with the PlayMemories 5.0 app
  • WiFi and NFC connectivity for simple tethering to a smartphone.
1 Comment
