Partilhe a sua experiência!
+971 58 156 5728 ABORTION PILLS IN UAE (DUBAI, SHARIAH, AJMAN, UMM AL QUWAIN, RAS AL KHAIMAH, FUJAIRAH, ALAIN AND ABU DHABI) ABORTION PILLS IN KUWAIT-KUWAIT CITY, QATAR-DOHA, OMAN-MUSCAT & SAUDI ARABIA.
Reach us on whatsapp +971 58 156 5728 for a safe medical/ abortion pill and surgical abortion in UAE. We offer medical abortion pills through online services with a cash on delivery service(COD) to our clients in Dubai, Abu Dhabi, Ajman, umm al Quwain, Ras al khaimah, Sharjah and Fujairah. For surgical abortion in UAE our clients reach us through our whatsapp +971 58 156 5728 and we arrange an appointment. Abortion is safe and discreet because it’s performed by our well trained and experienced obstetrician.
ABORTION/PREGNANCY TERMINATION IN DUBAI/UAE/ABU DHABI
What is pregnancy abortion?
Pregnancy abortion is the termination of an embryo or fetus from the uterus.
If an abortion occurs without inducement it’s referred to as a “miscarriage”. If effort is made to bring about an abortion it’s referred to as “induced abortion.”
There are two kinds of ways to achieve an “induced abortion”;
Non-surgical abortion/medical abortion/abortion pill
Surgical abortion/in-clinic abortion/vacuum aspiration
Abortion pill/medical abortion in Dubai/UAE/Abu Dhabi
Medical abortion is the process where a pregnant woman uses pills/tablets to end a pregnancy. Medical abortion is safe and more effective in the first trimester of a pregnancy (early stages).
A medical abortion does not require any kind of surgery and neither does it require any anesthesia, it can be done at the comfort of one’s home.
However medical abortion/abortion pill is not recommended if a woman is under the following conditions;
Ectopic pregnancy
If the pregnancy is more than three months
If you have an ongoing medical condition like; heart disease, bleeding disorders, kidney or lung disease, uncontrolled seizures
If you have allergies with the medicine used, that’s mifepristone and misoprostol (cytotec 200 mcg)
In such conditions a surgical abortion (dilation & curettage) alternative should be applied.
Types of medications and procedures for a medical abortion/abortion pill in Dubai/Abu Dhabi
Mifepristone (RU 486) and Misoprostol (cytotec 200mcg)-MIFE-KIT in Dubai
This is a combination of two medications, mifepristone which blocks the hormone progesterone hence stopping the growth of the fetus by preventing it from staying implanted on the uterus and misoprostol which contracts the walls of the uterus hence flushing out the fetus through the vagina.
Oral misoprostol in Abu Dhabi/ Dubai/UAE
Misoprostol is sold under brand name cytotec200mcg or Misoclear; it’s mostly used to terminate unwanted pregnancy in the 1st trimester of a pregnancy.
The abortion is done by placing the misoprostol pills under the tongue to dissolve as one swallows the solvent. The process takes about to 30 minutes before all the pills dissolve and the results take effect in an average of 1 to 2 hours, although there can be a delay in some individuals the window for the result is 24 hours after orally taking misoprostol.
Vaginal and oral misoprostol
This is the process where some pills of misoprostol are placed under the tongue and some are placed in the vaginal route.
This kind of procedure reduces side effects and more effective on early pregnancies.
Methotrexate
This is given in form of a shot and is used to terminate ectopic pregnancies (tubal pregnancy), methotrexate takes a while before it completes the abortion and it must be administered with some vaginal misoprostol.
Vaginal misoprostol/Misoclear
This is the process where misoprostol is only placed in the vaginal route, it should be used in abortion of very early pregnancies and its less effective compared to the other methods of medical abortion.
Symptoms after taking misoprostol
After using medicine for abortion one is expected to experience the following;
Abdominal cramping
Vaginal bleeding
Nausea
Chills
Fever
Vomiting
Headaches
Diarrhea
There is medicine for example ibuprofen that is used to manage the pain in case of severe abdominal cramps and also antibiotics for example ampiclox 500mg is used in case of infections after abortion although it’s very rare.
How to know that an abortion has been successful
In most cases it’s easy for one to tell that the abortion was successful when some of the symptoms like nausea and breast tenderness begin to disappear within days after abortion and in some situations one is able to see the embryonic sac during the bleeding, but it’s very important for one to; carry out a urine pregnancy test weeks after the abortion to confirm if it’s a negative test result.
In some cases one needs to take an ultra sound test to confirm whether the abortion was successful or not, the ultra sound test is much effective and gives the result as soon as the abortion is completed.
After abortion it might take about 2 to 3 weeks in some cases for ovulation to occur even before your period starts, so it’s safe to use contraceptive methods to prevent conception.
SURGICAL ABORTION IN Dubai/ UAE
Surgical abortion involves the dilating of the uterus open/cervix then inserting a suction tube into the uterus and used to vacuum out the fetus and placenta from the uterus.
A local anesthesia is used to prevent the pain during the process.
Surgical abortion is a minor procedure that lasts for about 20 minutes on average.
After surgical abortion you might need to be given some antibiotics to prevent any possible infections.
Surgical abortion is safe and effective once done by professional medical personnel and its success rate is 99%.
EMERGENCY CONTRACEPTIVES/EMERGENCY PILLS
Emergency contraceptive pills or morning-after pills are used to delay or disrupt ovulation in women hence preventing unwanted pregnancy.
Emergency pills are only effective to prevent unwanted pregnancy only in 72 hours after unprotected sex. Emergency contraceptives cannot terminate an already established pregnancy, so for emergency pills to be effective, they should be swallowed as soon as possible after unprotected sex.
Types of emergency contraceptive pills sold in Dubai;
Levonorgestrel containing pills are effective in 72 hours after unprotected sex, these include ipills, jasmine, Lydia, Postinar, etc.
Ulipristal acetate containing pills are effective in 120 hours after unprotected sex.
Tags
Abortion pills in dubai, abortion pills in Sharjah, abortion pills in Ajman, abortion pills in umm al Quwain, abortion pills in Ras al khaimah, abortion pills in Fujairah, abortion pills in Abu Dhabi, abortion pills in alain, abortion pills in satwa, abortion pills in Dubai marina, abortion pills in jvc, abortion pills in Jumeirah, abortion pills in bur dubai, abortion pills in al Khawaneej, abortion pills in al barsha, abortion pills in Diba, abortion pills in Madinat Zayed, abortion pills –abortion clinic in dubai, abortion clinic in Sharjah, abortion clinic in Ajman, abortion clinic in umm al Quwain, abortion clinic in alain, abortion clinic in Fujairah, abortion clinic in Ras al khaimah, abortion clinic in Abudhabi, abortion clinic in UAE, abortion clinic in Kalba, abortion clinic in Khor fakkan, unwanted pregnancy in UAE, unwanted pregnancy in Dubai, unwanted pregnancy in Abudhabi, abortion tablets in dubai, abortion tablets in Abu Dhabi, abortion tablets in Sharjah, abortion tablets in Fujairah, abortion tablets in Ras al khaimah, abortion tablets in UAE, abortion medicine in Dubai, abortion medicine in Abudhabi, abortion medicine in Ajman, abortion medicine in umm al Quwain, abortion medicine in Ras al khaimah, abortion medicine in alain, abortion medicine in Fujairah, abortion medicine in dubai marina, abortion medicine in UAE, abortion pills available in dubai, abortion pills available in Abu Dhabi, abortion pills available in Fujairah, abortion pills available in Ras al khaimah, abortion pills available in alain, abortion pills available in UAE, price of abortion pills in UAE, price of abortion pills in Abu Dhabi, price of abortion pills in Dubai, price of abortion pills in Fujairah, price of abortion pills in Ras al khaimah, price of abortion pills in Ajman, abortion pill cost in UAE, abortion pill cost in dubai, abortion pill cost in Abu Dhabi, abortion pill cost in Fujairah, abortion pill cost in Ras al khaimah, abortion pill cost in dubai marina, abortion pill cost in Sharjah, abortion pill cost in umm al
Quwain, abortion pill cost in Ajman, abortion in UAE, abortion in dubai, abortion in Abu Dhabi, abortion in dubai marina, abortion in Fujairah, abortion in Ras al khaimah, abortion pills legal in UAE, abortion pills legal in dubai, abortion pills legal in Abu Dhabi, abortion UAE unmarried, cytotec abortion pills in UAE, cytotec abortion pills in Dubai, cytotec abortion pills in Abu Dhabi, price of cytotec in UAE, price of cytotec in dubai, price of cytotec in Abu Dhabi, price of cytotec in Fujairah, price of cytotec in Ras al khaimah, misoprostol in UAE, misoprostol in Abu Dhabi, misoprostol in Dubai, mifepristone in UAE, mifepristone in dubai, mifepristone in Abu Dhabi, mifepristone in fujairah, misoprostol in Ras al khaimah, misoprostol in fujairah, mife kit in UAE, mife kit in dubai, mife kit in Abu Dhabi, Mifeprex in UAE, mifegest in UAE, cytotec 200mcg in Ajman, Misoclear in UAE, Misoclear in dubai, Misoclear in Abu Dhabi, Misoclear in fujairah, where to buy abortion pills in UAE, where to buy abortion pills in Dubai, where to buy abortion pills in Abu Dhabi, where to buy abortion pills in fujairah, where to buy abortion pills in Ras al khaimah, where to buy abortion pills in Sharjah, where to buy abortion pills in Ajman, Misoclear tablet price in UAE, abortion pills near me in UAE, abortion pills near me in Dubai, abortion pills near me in Abu Dhabi, abortion pills for sale in UAE, how to buy abortion pills in UAE, how to buy abortion pills in Dubai, how to buy abortion pills in Abu Dhabi, is abortion allowed in UAE, is abortion legal in UAE, morning after pill in UAE, morning after pill in Dubai, morning after pill in Abu Dhabi, morning after in Dubai marina, morning after pill in fujairah, morning after pill in Ras al khaimah, ipills in UAE, ipills in dubai, ipills in Abu Dhabi, ipills in dubai marina, ipills in fujairah, emergency pills in UAE, birth control pills in UAE, birth control pills in Dubai, abortion pills online in Dubai, abortion pills online in UAE,RU 486 in UAE,RU 486 in Dubai, RU 486 in Dubai, abortion pills on amazon, surgical abortion in UAE, surgical abortion in Dubai, surgical abortion in Abudhabi, surgical abortion in Fujairah, D&C in UAE, dilation curettage in UAE, mifepristone & misoprostol in UAE, mifepristone & misoprostol in Dubai, mifepristone & misoprostol in Abudhabi, mifegest in UAE, pregnancy termination pills in UAE, pregnancy termination pills in Dubai, pregnancy termination pills in Abu dhabi, pregnancy termination pills in Fujairah, pregnancy termination pills in Ras al khaimah, pregnancy termination pills in Ajman, pregnancy termination pills in Sharjah, unwanted pregnancy in UAE, unwanted pregnancy in Dubai, unwanted pregnancy in Abudhabi, unwanted pregnancy in Fujairah, unwanted pregnancy in Ras al khaimah, abortion hospital in UAE, safe abortion in UAE, safe abortion in Dubai, safe abortion in Abudhabi, unplanned pregnancy in UAE, unplanned pregnancy in Dubai, unplanned pregnancy in Abu Dhabi, unplanned pregnancy in Dubai marina, prescription abortion pills in UAE, abortion pills on black market in UAE, abortion pills near me, cost for D&C in UAE, cost for D&C in Dubai, cost for D&C in Abudhabi, cost of surgical abortion in UAE.
MTP kit kaise use kare, sahi tarika, Side Effects, bleeding time, MTP Abortion pill ?????, ??????, ???? ka sahi tarika. Abortion kaise hota hai. this video gives complete information about medical termination of pregnancy pills. what is the correct dose and time, complications of the pill, frequently asked questions.
#MTPkit #Abortionkit
Visit us at- https://www.drmayurigynecology.com/vi...
Medical termination of Pregnancy (MTP) is when pregnancy is aborted with the help of medicines.
Q1. When should we take MTP pills- 1:00 min to 1:50 min- In unwanted pregnancies, MTP pills should be taken only upto 7 weeks of pregnancy i.e. upto 49 days and not beyond that.
Q2. How to take MTP pills- 1:52 min to 4:10 min- MTP pills come in a pack of 5 pills, first one is to be taken orally with water and after a gap of 48 hours, rest 4 pills have to be taken sublingually.
Q3. How does MTP pill work- 4:15 min to 5:45 min- Mifepristone is progesterone antagonist and ends the growth of pregnancy. Misoprostol causes uterine motility and contractions, this causes expulsion of pregnancy.
Bleeding after MTP pills- 5:59 min to 7:15 min
Q4. Side effects of Misoprostol- 7:20 min to 8:20 min- Fever, Vomiting, heavy bleeding, severe pain are a few side effects of misoprostol.
Q5. Precautions to be taken before MTP pills- 8:25 min to -12:50 min Anaemia, allergy, bleeding disorders, chronic liver disease, kidney disease and any other medical illness. Breast feeding mothers should be careful with its use. Always take them after confirmation of pregnancy on ultrasound.
Q6. Side effects of MTP pills- 13:00 min to 13:30 min - Fever, heavy bleeding, pain and diarrhoea that persists after 24 hours of tablet needs medical treatment.
Q7. When is the second visit or follow up visit after MTP- 13:40 min to 14:15 min- This should be planned after 14 days of abortion pills or earlier if emergency signs develop.
Q8. What are the Emergency signs after MTP pills-14:30 min to - heavy bleeding and pain, high grade fever, foul smelling discharge.
Q9. What are the complications of MTP pills- 15:50 min to 16:15 min- Incomplete abortion, septic abortion, anaemia, ruptured ectopic are a few of the many complications of MTP pills
Q10. What is the effect of MTP pill on future pregnancy- 16:20 min to 17:05 min- Single use of MTP pills has no effect on future pregnancies.
How many times can you take MTP pills- 17:10 min to 17:25 min- It is preferred that the use of MTP pills should be limited and these should not be used in place of routine contraceptives.
Q11. When should we do pregnancy test after taking MTP pills-17:30 min to 18:30 min- urine pregnancy test can be positive even after 1 month of MTP pills, so this should not be used for confirmation of abortion.
All the information in this video is authentic and solely for patient education purpose.
Facebook:
/ dr.mayuri.gynecology.clinic.jaipur
Website: https://www.drmayurigynecology.com/
Address: 11-12, Laxmi Nagar, Sitabadi, Tonk Rd, Near Airport, Jaipur, Rajasthan 302029
Email: dr.mayuri.obgy@gmail.com
(MEDICAL DISCLAIMER:-
The information provided in this video is intended to provide free education about certain medical conditions and certain possible treatment. It is not a substitute for examination, diagnosis, treatment, and medical care provided by a licensed and qualified health professional. If you believe you, your child or someone you know suffers from the conditions described herein, please see your health care provider immediately. Do not attempt to treat yourself, your child, or anyone else without proper medical supervision. Our video or channel does not promote taking pharmaceutical goods without prescription from any source.
You acknowledge and agree that our Youtube channel is not liable for any loss or damage which may be incurred by you as a result of the availability of that information provided here, or as a result of any reliance placed by you on the completeness, accuracy or existence of any information provided by our YouTube channel 'Dr. Mayuri Gynecology Clinic')
