does anybody know how to get the swift keyboard back on my phone as it seems to have been disabled
Hi @agc66,
If you have disabled SwiftKey you can enable it by going to: Settings > Apps > Tap All apps > Disabled > SwiftKey Keyboard > Enable.
Then go to: Settings > Language & input > Current keyboard > SwiftKey Keyboard, to select SwiftKey as your current keyboard app.
Let me know if this helps!
