Broken Laptop
pekenny31
Broken Laptop
Hi
My main laptop has packed in, I do have a netbook that I use occasionally, can I just plug my reader into the netbook without losing my library on the reader ?
Any advice please
Peter
Thalamus.
Champion
Hi Peter,
welcome to Questions & Answers..:smileyhappy:
Yes you can, just to be on the safe side disconnect your reader via safely remove hardware in the system tray before unplugging the USB..:smileywink:
Thalamus.
Champion
Hi Peter,
pekenny31
HI Thalamus,
Thank you for the advice.
Unfortunately my laptop is beyond repair  :slight_frown:
I'm now trying to get my reader to sync with my netbook (without much success) any
advice, the last thing I want to do is erase the library on my reader.
Cheers Thalamus
Peter
