- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
Hello,
Recently purchased sony e-reader PRS-T2. I have created my e-store account and can access it through my laptop.
When I tried to login in to reader e-store through reader device (connected to internet through wi-fi) it throws error 401. It says internal system error.
Any clue what is happening ?
thanks,
Solved! Go to Solution.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
I had the same problem with mine. In the end I re-registered with the reader store via the e-reader, using another email address and haven't had the problem since then.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Wll, I may be wrong here, but I think 401 is an error relating to unauthorized access - in other words, your PC says you're not authorized to do what you're trying to do.
It may be your router, or a block in your PC .
But someone more tech-minded on the PC side will hopefully weigh-in with a better explanation, and a solution.
Have you rechecked to make quite sure you have done all the correct procedure to authorize etc .. ?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
