Password problems...
carpetmojo
Anyone else have password problems ?
I've had this performance before a few times, now and then it asks me for my e/ml & password
before logging me in, when I insert (correct) email, password "dots" appear. If I hit go, up comes "e/ml or p/wrd incorrect...".
So I go back , insert (correct) e/ml, cancel the dots, insert the last p/word  I have (and had for quite a while now..) . I select "Remember me", hit go, and all is well.
BUT  the correct p/wrd is NEVER "remembered" correctly the next b....y time I am asked to log-in....:smileyangry:
And should I be daft enuff to "Change my Password" - forget it, I'mthen trapped in a loop that usually ends up with me either not being able to change,  having no recognised p/wrd, having to contact Support for another...... or resorting to the Glenmorangie.
Which is nice, but not the original idea !
So, I've tried "Remember me", again , this time  ... but have no idea if it's going to not work again/work, and I don't have the time/patience to waste time trying it out :thinking:
Oh gawd.......
0 REPLIES 0
