R4PC will not accept my Adobe ID
sarahlou128
I really need some help, I have been given a Sony PRS-T1, I have downloaded the reader for pc software but when the prompt box appears for me adobe ID it will not accept it (even though I have checked the ID works on the Adobe main site.....  The reader says its authorised for DRM but when I cannot add books on via Sony reader as it wont activate my account, and I cannot use Calibre as the book says DRM content protected (even though the device says authorised for DRM viewing in the about section!) Please help,
4 REPLIES 4
sehuxle
It sounds like the reader is already authorised to the previous owner. You can only authorise the reader to one Adobe ID.
You therefore need to de-authorise the reader first to remove the previous Adobe ID authorisation. Then re-authorise to your Adbobe ID.
sarahlou128
Thank you- do you know how I can do this- or does it have to be done by previous owners? I did find a fix using adobe digital editions but this is not compatible with the prs-t1......
Your help is appreciated as I have got very frustrated with it!
sehuxle
You've two options
1 ask the previous owner to do it, they need to plug it into their computer and use R4PC to de-authorise.
2 you can do a hard reset, this will erase everything and enable to start a fresh. For this just google 'hard reset for sony T1'
carpetmojo
Well, I thought I'd look, using the "helpful" search facility..... The first thing to hit me was it does not recognise the tag "outhorise" ! Then it told me it did not recognise the tag "owner" !!  :thinking:
Ridiculous - I know there are some posts on authorising to new owner, but can't find 'em...
Hopefully someone else can help.
I would presume you'll need their password etc ....but I don't know for sure.
Check your PM's.
