The message you are trying to access is permanently deleted.
just bought PRS T2 to replace my old e-reader, books in library from waterstone. How can I transfer the books to the new reader, been trying for 3 hours Any help appreciated.
Solved! Go to Solution.
You will need to use the Sony reader software as digital editions doesn't work with the new readers.
When you install the software it should ask for your Adobe ID. Use the same one as used on digital editions.
You should then be able to transfer all your books using the reader software
