A7ii
profile.country.GR.title
NIKOS-TSIDILAS
A7ii
recently buy sony a7ii but in video i see noise in 3200 iso and more,does anyone has same problem?
Mick_D
Moderator
Hi @NIKOS-TSIDILAS, welcome to the community.
If you shoot 3200 ISO you are very likely to see noise in the shadow areas. This is normal, especially if you are under-exposing. Try shooting at lower ISO, light your subject better, or look for processing solutions that will reduce noise.
At higher ISO, you will generally see less noise if you over-expose slightly, but it's difficult to give any specific advice without seeng the problem first-hand. Uploading or linking to examples of the problem would help!
Best wishes
Mick
NIKOS-TSIDILAS
can sou sent me an e-mail to send the video?
Sean_Mc
Moderator
Hi there,
If you contact the support team here they'll be able to advise further.
Best wishes,
Sean
