bateria muerta????
migfernn2
bateria muerta????
mi portatil sony vaio ns11s/z hace unos dias que no reconoce la bateria sale una x en rojo encima de la bateria abajo a la derecha y no carga nada,  no he cambiado nada ni sistema operativo ni nada, quiere decir que se ha muerto la bateria?,. Si compro una NO original funcionará?
my sony vaio laptop ns11s / z few days that does not recognize the battery leaves a red x over the battery down to the right and do not charge anything, I have not changed anything or operating system or anything, it means that the dead battery?,. If I buy an aftermarket work?
English translation added by Community Manager.
jumpsuit
Hi migfernn2 and welcome to the Community :slight_smile:
I'm sorry I can't answer in Spanish, I don't trust Google translate either.
I don't know if you speak English, but yes it sounds like your battery has died.
If you buy a replacement battery then that should solve the problem. (Check on Ebay etc.)
