cannot get sound to my bravia tv from my "old" sony blue ray player , i have a picture ...????
bluedog..
I have aSony KDX Bravia tv and cannot get any sound from my "old" sony blue ray player when trying to play a DVD...So frustrating.... i have tried problem solving on various websites with no luck. Its connected with a HDMI cable only and i have a picture.
ive tried various settings on my Tv with no luck.
I have a soundbar connected to my Tv by bluetooth.
Any Help much appreciated
6 REPLIES 6
Pascale_F
Moderator
Hi bluedog..,
Welcome to the community.
I'll see if I can find this out for you. Maybe someone else in the community can help in the meantime.
Thanks,
Pascale
The_Black_Rose
Specialist
Hi Bluedog,
What's the model number of the TV?
Cheers,
The_Black_Rose
bluedog..
Thanks for your reply , it's a Kd-49Xf90xx
Model.
I have a sony soundbar too.
I have just got a Wii to work with picture and sound through an adapter and
a hdmi.
Many thanks
The_Black_Rose
Specialist
Hi Bluedog,
Is the sound bar connected via ARC? Can you give me more details about the whole connection map?
Cheers,
The_Black_Rose
bluedog..
My sound bar is connected to the Tv via bluetooth.
Sorry to be vague but im not tech savvy and this has completely thrown me .
My Sony DVD player is connected via a HDMi into an empty Tv port.
The picture is always there but never any sound. Iv tried turning the
sound bar off completely and changing the TV speakers to Tv only. rather
than audio.
Im stuck ! Ive tried you tubing the problem with no help either.... Not
sure wether to try a new HDMI cable ?
Many thanks
The_Black_Rose
Specialist
Hi Bluedog,
I'd recommend trying different types of connections like HDMI cable or optical cable if available and test it to identify the cause of the problem.
Also, make sure that the speakers on your TV are set to Audio system not TV speakers in the speaker settings.
Cheers,
The_Black_Rose
