goldsilver15
DONT BUY ANY SONY TV
SONY af8 in particular it makes cracking sounds tht are not quiet and you hear them 20 a hr in first hr and then 10 in hrs to come. so if you just use the tv for an hr listenig to all the sounds the different sort of cracking then turn it off then go out come back in turn your tv on again to then listen for another 2-3 hrs of cracking noises would tht not annoy anyone ?
And sony say basically nothing we can do your just going to have to deal with it cause thts wot our tv do
ive had the same tv and tht didnt make cracking noises so they are wrong and dont care about your needs just want your money
on a £2500 tv wot a joke
wont be buying sony products as this has changed my whole outlook on sony and their products
0 REPLIES 0
