HT-ZF9 sound bar
HT-ZF9 sound bar
Can I use my sound bar as a hub? When I check my wi-fi choose a network it shows my sound bar, but no matter what I try I cannot get logged on through it as it is locked. Have tried the settings to see if I can change it and there is nothing in the settings to change the password for the internet connection on the sound bar. Is there a default code setting for logging anything to it through the wi-if? Or is it a trip to my local Sony centre. Thanks guys
EdwinaU
Moderator
Hi Wilrussell,
We will check for you and update this thread when we find out more. Maybe some other members will have some know-how to share.
Best wishes,
Ed
Vanilla_
Hi wilrussel,
I don't believe this connection is supported as I couldn't locate it anywhere in the User manual of this soundbar. I believe that you can only connect the soundbar to the network.
Regards,
Vanilla
