Karaoke EQ
Natmac66
Karaoke EQ
I've just had a new radio installed in my car (mex 43000bt).it is supposed to have a karaoke EQ function (as per box and description) but I can't find anything about it in the manual. Would anyone know where to find this function?
IamNic
Hello @Natmac66,
I found this on page 20 of the manual (if you are referring to the MEX-N4300BT):
Sound Setup (SOUND)
This setup menu is not available when the
source is off and the clock is displayed.
EQ10 PRESET (EQ10 preset)
Selects an equalizer curve from 10
equalizer curves or off:
[OFF], [R&B], [ROCK], [POP], [HIP-HOP],
[EDM], [JAZZ], [SOUL], [COUNTRY],
[KARAOKE]*, [CUSTOM].
The equalizer curve setting can be
memorized for each source.
* [KARAOKE] reduces the vocal sound but
cannot fully remove it during playback. Also,
using a microphone is not supported.
- Nic
