KD49x8309c
RJH001
KD49x8309c
Can anyone suggest on where to get assistance with the TV which does not respond to either the remote or to the tv controls. Can not change Chanel or adjust sound. The only thing the report allows is turn the tv on (not off)
DarranA
Moderator
Hi RJH001,
If you are certain the remote has power and are experiencing these issues I would advise you to contact Sony Support here
Thanks,
Darran
