Minolta 300mm f4.
Altondp
Minolta 300mm f4.
Minolta 300mm f4
I just purchase an Sony A7R3 and I was wondering if my Minolta 300mm f4 land a couple of Konica-Minolta lenses canwork with an adapter with my new purchase, can anyone give me any advise on this.
Hi there,
Hopefully a community will be able to help.
Best wishes,
M
Are your Minolta lenses autofocus? If so, are they screw driven for the AF or do they have a SSM motor in the lens?
The Sony adapter LA-EA3 will only work on Minolta lenses with their own AF motors (SSM, SAM). The LA-EA4 should work with any lens but there may be a light loss as the adapter is SLT and you may need to compensate for the half-stop loss.
https://www.sony.co.th/en/electronics/support/articles/00021281
To use with manual focus and manual exposure is much cheaper!!
https://www.amazon.com/dp/B01IDDXGL0/ref=psdc_3347321_t2_B01M7UJQMJ
Vanilla_
Hi Altondp,
I've looked up the compatible lenses with your camera.  I think yours is the "AF APO 300/4 G". If yes, you'll find the right adapters you can use on the same page: https://support.d-imaging.sony.co.jp/www/cscs/lens_body/?mdl=ILCE-7RM3&area=gwt&lang=en_GB
Cheers,
Vanilla_
