Miserable life with AF9 (WiFi this time)
Calib_Moxley
55-AF9 and Wifi won't connect to Wifi access point. If finds all the available WiFi SSIDs, but after entering the password, it says that "Couldn't find <ssid>". I have tried with two different access points. Same result.
Why is TV this expensive full of problems!
Marino.Manolo
Genius
Try to reboot Android TV keeping pressed Power/OFF on remote and retry...
Calib_Moxley
Reboot does not help. Tried several times (cold boot - not just standby off/on of course).
I tried to connect to three different APs. Using easy setup error message says that the password is not corrct. I am 100% sure that I enter the right one. This started after 2/2020 upgrade.
Another issue that started after upgrade (2/2020) is that EPG is missing about 30% of information. Another two Sony TVs do not have this kind of problem. EPG is 100% up to date. Cable etc. checked and changed. Signal quality 100%.
