MP3 Player & Spotify
I all, I am looking for an MP3 player with the ability to have my Spotify account on, also that has a digital radio for listening to DAB stations, cricket etc. I want a really high quality sound.
Could any one help me pls?
i understand there's a ZX3 due out in June? Would this fit the bill?
Thanks in advance
jumpsuit
Hi @Gabylulu01 and welcome to the Communtiy :slight_smile:
The good news is that you can use Spotify (and other apps) on any walkman that has Android on it, the ZX2 beingone example. The sound quality on that model is superb too. :slight_smile:
Unfortunately though it doesn't have DAB, and neither do the other high resolution Walkmans.
You may have to compromise a little.
I don't have any info on a ZX3, but will keep an eye out.
Hope this helps.
Thanks for the Swift reply Jumpsuit, do you know if a DAB app can be downloaded to he device to use?
jumpsuit
Hi again :slight_smile:
I don't think there are any actual DAB apps
but there are plenty of radio / streaming apps available e.g iHeartRadio.
Have a look Here
for more examples of apps :slight_smile:
