Noises from back of TV
petesledtv
My TV makes clicking noises from the back, it sounds like static electricity being discharged. Anyone else have this happening ?
jumpsuit
Just updating the thread...
The member let me know they have contacted Support who
have said it is just components expanding and contracting when
they get hot, it's normal.
jumpsuit
Hi @petesledtv and welcome to the Community :slight_smile:
It could be several things.
Has it recently started or has it always done it?
Which TV do you have?
If its an old model it may relate to noise caused by TV guide trying to connect.
Some disabled the TV Guide and it sorted the problem.
Another had success by powering off and disconnecting the cable for a few minutes, then reconnecting the cable and powering on again.
Again, they were for old TVs
jumpsuit
