notifications. tones
luskrzy74
Handset is using ear speaker instead of bottom one
luskrzy74
I mean if someone is calling you or texting you can hear very quiet sond from your handset
Hi there
You might be best to post this in the dedicated Mobile forums instead.  Also you might want to include what model it is as well - the more relevent details you provide, the more likely you will get a solution to your question.
luskrzy74
Is xperia z1 2 days old is replacement for 4 days old with this same problem
