Playmemories Home Add sound file
HMalik
Hi  I want to add a sound file to my edited video.  I can only see the default sound files and if I try to add a file from my computer, this does not work.
I have noted there is an option to do this but it does not work.   I am currently using PlayMemories Home Version 6.0.00.12211
Look forward to hear from you.
I cannot see how I would know if someone can help me . If possible please email me the fix.
[*The personal email address was redacted by a moderator*]
Kind Regards
H. Malik
IamNic
Hello @HMalik,
the video editor within PlayMemories is such a cumbersome piece of software which hasn't really seen much love over the last years.
Though for me it works to add a file. Where do you click to add it, maybe share a screenshot. Which file format is the music/sound file in which you are trying to add?
Even if we figure out what the issue was, if I were you, I would use any other (free) editing software like "DaVinci Resolve".
My personal recommendation would be "Magix Movie Edit Pro" (not free).
- Nic
HMalik
Thank you.
I have also found that playmemories has a limit of 4GB when you render the final video file.
I have also found that the write to disc is also difficult to use, even though I have used the same files, registered the camera used, it still keep on prompting as unrecognised format.
I will use Devinci Resolve.
IamNic
Hello @HMalik,
as stated before - I would recommend to use another editing software.
- Nic
