I'm trying to apply for the Sony EGP, but the application link seems to be broken. When I click it, it leads me to a page that says "Sorry, there are no jobs available." Does anyone happen to know how I can access the application, or if there's a better place to ask? Thanks a bunch!
Solved! Go to Solution.
Hi all,
I was told there was some delay in the program start, a new date will be announced on the website soon.
Please bear with us while this gets sorted.
No need to further escalate or contact internally.
Kindest regards,
Nico
I believe our EGP programs are running from September till June.
So that must be the reason why you can't submit your applications for the moment.
Kindest regards,
Nico
Are you looking to apply for the Sony European Graduate Programme?
The application period runs from the 1st November 2013 to the 15th January, therefore you should be able to Click on Apply and simply follow the instructions below.
@Nobody-in-particular wrote:Are you looking to apply for the Sony European Graduate Programme?
Emphasis is mine. I completely agree with you, but the Apply link is unfortunately broken.
It would appear so, I have searched around and cannot find any contact details for the Sony EGP team, perhaps if you send a Private Message to one of the Sony employees they will be to supply a contact email address or telephone number.
Hello
I have got the same problem. I have been waiting to apply to EGP since November 1st, however, it seems like the vacancy is still not live. Could someone kindly provide us with e-mail address of Sony recruitment office. I would be very greatful.
Best regards
Just checking if you have any updates on the issue. Going by the dates mentioned on the website there are just a little over 2 weeks left. Thanks in advance
