Sony 2012 Catalogue
KushMonkey
Sony 2012 Catalogue
Hi. Is it possible Sony can send one to me? Many thanks. :slight_smile:
-Cass-
Hi KushMonkey,
Welcome to the forums.
Unfortunately Sony no longer print catalogues.
However, you can find all the information on all ranges of Sony products on the Sony website here.
Kind regards,
Cass
Forum Moderator
-Cass-
Hi KushMonkey,
Kind regards,
Cass
Forum Moderator
mydearcosmo
I have the same question. Can I print any manuals Sony has online? Or are there none?
carpetmojo
There's everything easily available - go to Support, top of this page, then Reader support, then select your model, and.... there :slight_smile:
