Sony bdv 3100
Niki6371
Sony bdv 3100
I have a Sony bdv 3100
and the last two outputs are not working now.. Never had an issue before but the speakers do work just not the ports
any solutions to this issue?
10 REPLIES 10
Did you test it with different speakers and cables?
Niki6371
yes the speakers work fine
Niki6371
It’s just the last two out put on the unit .. They just don’t work
HannahEd01
Community Team
Hi Niki6371, what do you mean with two outputs? Two speakers?
Niki6371
If your looking at the back of the unit
the last 2 jacks where you hook the speakers too does not work
i tested the speakers and they are working
Niki6371
Niki6371
Does anyone have any idea as to how to fix this issue…
HannahEd01
Community Team
Hey Niki6371, if you tested different cables, reset the device, and did the unplugging step, then you need to send it for repair: http://bit.ly/2DJn2JC
Niki6371
I unplugged the unit leaving it about 10 minutes and the speakers do work so I know that’s that’s not the issue
is there a fuse are something inside that I should check for?
