Sony kdl 32wd751G
Flyboi
Sony kdl 32wd751G
Hi
The above TV is only connected via wifi. We have no problems watching you tube or netfix as the apps are there. How do I add apps please ? Either by on the TV or an external USB device via wifi
Mick_D
Moderator
Hi @Flyboi, welcome to the community.
I can't seem to locate your model TV, but if you don't see a Google Play icon, you have a non-Android TV. The best way to find apps is by using a USB device – Firestick or similar – which should work fine over wifi.
Mick
