Sony Soundbar HT CT260
RichC9
Hello everyone.
As a new member was sort of looking for a little help.
I've owned a Sony soundbar HT CT260 for a couple of years now. Great performance and amazing addition to Bravia TV.
Just the last few days while the power is off the Bluetooth (blue light) is continually flashing as if looking for a connection. It only does it when I turn power to off/stand by. I've tried unplugging for several minutes to try a reset but to no avail. Everything works as it should I.e sound and Bluetooth connection works. It's just very baffling.
Was hoping someone may have some ideas.
It started happening out of the blue if you'll pardon the pun but I'd not used Bluetooth at the time the fault started happening.
Has anyone any ideas.
Thanks in appreciation.
2 ACCEPTED SOLUTIONS
Pascale_F
Moderator
Hi RichC9,
Welcome to the community.
I'm just going to try to find some answers for you. In the meantime, maybe someone else in the community might have some ideas.
Thanks,
Pascale
Win_88
Specialist
Hi RichC9,
Have you tried resetting the soundbar to factory settings? You can find the steps on page 38 of the user manual.
Win_88
Pascale_F
Moderator
Hi RichC9,
Thanks,
Pascale
Win_88
Specialist
Hi RichC9,
Win_88
RichC9
Hiya
      Many thanks for info. I tried that and its worked perfectly since.
Thanks for all suggestions.
Regards Rich
