Sony Vaio VGN-FZ21Z
umarkal
Sony Vaio VGN-FZ21Z
Hello.
My laptop is not starting and sony didnt supply me with vista recovery disk!
Where am i able to purchase that?
Thalamus.
Champion
Hi umarkal,
welcome to Questions & Answers..
Are you getting any error messages when starting your vaio..:smileyconfused:
Your  Vaio was supplied with a hidden HDD recovery partition so you should be able  to restore the Sony  supplied operating system and the pre-installed  applications by doing the following.
Note - If you recover your vaio you will loose any personal data that you havn't backed up..
Start  your Vaio and when you see the Vaio logo press the F10  key repeatedly,  hopefully this should start the recovery process using  the hidden HDD  recovery partition.
Then follow the recovery instructions to complete the process
If the F10 option does not work then you can contact Vaio support and purchase a set of recovery disc's for your vaio..
You   can find the contact details for vaio support by either clicking    Support at the top of this page or by using the following link:Vaio support
Under  Log-in option 1: enter your VAIO's serial number
Then click Log-In
Once logged select Get In Touch..
4 REPLIES 4
Thalamus.
Champion
Hi umarkal,
Then click Log-In
umarkal
Hey.
F10 doesnt work but the error says "The file is possibly corrupt. The file header checksum does not match the computed checksum"
I think ill have to contact vaio.
umarkal
Can i also go to my local store to get a recovery cd?
Thalamus.
Champion
No unfortunately the Sony stores do not carry recovery discs..:smileysad:
