soundbar
c10a1g94e3v36e14
soundbar
I have an old soundbar  SA-CT60BT           It does not respond to the remote       only one light on the bar comes on then it closes down    I have tried changing the battery  still no joy      is the soundbar kaput?
Mick_D
Moderator
Hi @c10a1g94e3v36e1e14, welcome to the Community.
The soundbar will shut down automatically if it doesn't receive a signal. Make sure the TV is on and the volume is turned up. You should also check your soundbar remote batteries. If it's still not working, you may need to replace or repair the unit.
Hope you get it going.
Mick
