Connect PSHX500 to SRSX99
I have a SRS-X99 speaker and am looking at a PS-HX500 turntable. Would I be able to connect the two directly or would I need something between?
Sonyvores
PS-HX500 has a built in phono amp so no problem. You need need a RCA to mini jack cable to connect both 😃 (Don't forget to select "Line" output on the turntable)
Sonyvores
Thanks - purchased the turntable and excellent sound. Appreciate the help, cheers.
Sonyvores
Great! enjoy 😃
